Comments Pagination Block
Go to the List of Blocks
The Comments Pagination block is part of the Comments block that displays paginated navigation to the previous or next comment sections.
By default, a Comments Pagination block is included when you insert a Comments block. However, you can still add this block manually.
Comment Pagination block inside Comment Query loop block
You can only insert the Comments Pagination block inside a Comments block.
To add the block, select the Comments block and hover your mouse over a blank space. Click the (+) icon to open the block inserter pop-up window. Look for the Comments Pagination block using the search bar and click on the block icon to add it to the Comments block.
Alternatively, add a Paragraph block within the Comments block and type /comments-pagination to insert the Comments Pagination block.
How to quickly add Comment Pagination block
Detailed instructions on adding blocks
Block toolbar
The block toolbar contains tools to customize each block on the editor quickly. The Comments Pagination block has the following tools:
Select comments block
The Select Comments tool lets highlight the Comment Pagination’s parent block, which is the Comments block.
Transform to
You can transform a Comment Pagination block into a Columns, or a Group block.
Transform option in the Comment Pagination block
Block-moving tools
Block moving tools for Comment Pagination block
The block-moving tools allow you to move the block up and down the editor. Use the six dots icon to drag and drop the Comments Pagination block and place it anywhere on the Comments block. Alternatively, click on the up and down arrows to move the block up or down.
Get more information about moving a block within the editor.
Change items justification
Change items justification for Comment Pagination block
The change items justification tool lets you change the horizontal placement of the items inside the Comment Pagination block. There are four options to choose from:
  • Justify items left will move the items towards the left side of the block.
  • Justify items center will move the items towards the center of the block.
  • Justify items right will move the items towards the right side of the block.
  • Space between items will distribute all items across the block and automatically adjust the space between them.
Change vertical alignment
Change vertical alignment for Comment Pagination block
The change vertical alignment tool lets you choose the vertical position of the items inside the Comments Pagination block. You can choose between top, middle, and bottom vertical alignment.
Change alignment
Change alignment for Comment Pagination block
Unlike the previous alignment tools, the change alignment tool is used for the Comments Pagination block’s position inside the Comments block. Choose one of the following block alignment options:
  • None
  • Align left
  • Align center
  • Align right
More options
These controls give you the option to copy, duplicate, and edit your block as HTML.
More options in the Comment Pagination block
Read about these and other settings.
Block settings
The block settings panel contains customization options specific to the block. To open it, select the block and click the cog icon next to the Publish button.
Here are the options for the Comments Pagination block:
Layout
Layout settings in the Comment Pagination block
In the layout section, you will find the following customization options:
  • Justification settings are similar to the tools in the block toolbar.
  • Orientation lets you choose to display the pagination items horizontally or vertically.
  • Allow to wrap to multiple lines toggle button lets you display the pagination items in multiple lines when needed.
Settings
More settings in the Comment Pagination block
The settings section shows three options for a decorative arrow to the next and previous comments link. Here are the options:
  • None
  • Arrow
  • Chevron
Color
Color settings in the Comment Pagination block
The color section lets you customize the text, background, and link color for the Comments Pagination block. Click on any of the options to change the color, and a pop-up to pick a color will appear. Choose from the default color or click the upper rectangle area to pick a custom color using the color picker.
Typography
Typography tool for the comment pagination block
The Typography settings enable you to customize the font and text appearance of the content within the Comments Pagination block. The settings have various options, such as font size, font style, font family, and letter spacing.
Learn more about the Typography settings.
Advanced
The “Advanced” tab lets you add CSS class(es) to your block. This will allow you to write custom CSS and styles to the block.
Advanced option in the selected Block
Comments Pagination inner blocks
The Comments Pagination block consists of the following three inner blocks (which can’t be inserted on their own):
  • Comments Previous Page block
  • Comments Page Numbers block
  • Comments Next Page block
The Comments Previous Page block displays the previous posts page link.
The Comments Page Numbers block displays a list of page numbers for pagination.
The Comments Next Page block displays the next posts page link.
All these blocks are located inside a Comments block and lets you customize the appearance of the pagination.
Block toolbar
Block toolbar in the pagination inner blocks
The block toolbar for all the Comments Pagination inner blocks – Comments Previous Page, Comments Page Numbers, and Comments Next Page contains the tools to customize each block.
Block-moving tools
Block moving tool in the pagination inner blocks
Use the block-moving tools to move the block up and down inside the editor. Use the six dots icon to drag and drop the block and reposition it anywhere on the editor. Alternatively, click on the up and down arrows to move the block up or down the editor.
More options
Page Numbers, Next Page and Previous page blocks share the same functionality for more block options button. Click on the three dots icon to show more options and a drop-down menu will appear.
Block settings
The block settings panel contains customization options specific to the block. To open it, select the block and click the Settings panel icon next to the Publish or Update button.
Here are the options for the Comments Pagination inner blocks.
Color
The Comments Pagination inner blocks – Comments Previous Page, Comments Page Numbers, and Comments Next Page provides color settings option to add background color.
For details refer to this support article: Color settings overview
Typography
The Comments Pagination inner blocks – Comments Previous Page, Comments Page Numbers, and Comments Next Page provides typography settings to change the font family, appearance, line height, letter spacing, decoration, letter case, and font size.
For details refer to this support article: Typography settings overview
Advanced
The Advanced tab lets you add CSS class(es) to your block. This will allow you to write custom CSS and styles for the block.
Advanced tab with additional CSS
Changelog
  • Updated 2024-01-23
    • Updated content for WordPress 6.4
    • Fixed block names
    • Added a new section for Comments Pagination inner blocks
  • Created 2022-08-02
Was this article helpful? How could it be improved?
First published
Last updated
