Next_Posts_Link not displays same posts (not next posts) when using Offset.
Hi Guys,
I’m editing the Main Index Template to give my site more of a magazine feel. I have 2 sections on the page that display featured stories and the 3 newest stories, both using the get_posts() query.
I’ve now laid out the remaining section, which uses the main wordpress loop. Due to the fact that I’ve already displayed 3 of the newest stories I do not want to display them again when the main loop runs, so I’ve been trying to use offset to achieve this.
The problem is that when I use offset the correct number of posts are skipped, but when I click the Next_Posts_Link the same posts are diplayed again on page 2, which should display the remaining posts.
I’ve tried the following to resolve this problem:
1)
query_posts(‘posts_per_page=6&offset=3’);The offset works, but the same four posts are displayed on page 2.
2)
<?php
$paged = (get_query_var(‘paged’)) ? get_query_var(‘paged’) : 1;
$args=array(
‘offset’=>3,
‘posts_per_page’=>6,
‘caller_get_posts’=>1,
‘paged’=>$paged,
query_posts($args);
?>Again, the offset works, but the same four posts are displayed on page 2.
3) I’ve tried creating a new WP_Query() object and referencing this in the loop, with the same results.
In all three cases, if I remove the offset parameter, when clicking the Next_Posts_Link the correct posts are displayed… all bar the three that I’m trying to skip.
If anyone could help, I’d be really grateful.
The topic ‘Next_Posts_Link not displays same posts (not next posts) when using Offset.’ is closed to new replies.
